$300 t56
Adding the LT1 front adapter plate will let you use an LT1 flywheel, fork, clutch and hydraulics. The LS1 front adapter plate will prevent clearance for the fork and lack mounting for the fork.
There isn't a lot of depth to the LT1 bellhousing area to begin with, so going with the LS1 front plate wouldn't magically let you run a push clutch. It has less room.
Also: Total carnage of the $300 T56 so far. All that damage I've found is from the 6th? Gear. I only have the rest of the mainshaft and shift rail to dissassemble after class tomorrow. I have to pick up a torx-plus T40 bolt. I tried using a normal T40 and some heat from a butane torch but it would just not budge..
The transmission in the Craigslist ad is not a T56....It is a T5 (5 speed) from a 3rd Gen f-body. You all know this, right?
Andrew
