What is the purpose/function of the T56 Transmission Bumper?
Old 01-03-2014, 09:04 AM
elesquan's Avatar
Default What is the purpose/function of the T56 Transmission Bumper?
This is the rubber thing bolted to the top of the tail housing, part 169 in the manual.
Just curious.
Old 01-03-2014, 09:48 AM
BALLSS's Avatar
it is a shock buffer between tunel & tranny. some who have put T56 in cars that did not come with that tranny, like me, have removed them due to tight clearance. FWIW I have not contact vibration between trany & tunel.
Old 01-03-2014, 11:05 AM
elesquan's Avatar
Thanks! What car do you have a T56 in ******? LS engine too?
I welded in the '98 Z28 firewall and trans tunnel into the el Camino, so I guess I will just leave the bumper on then.
Old 01-03-2014, 12:56 PM
BALLSS's Avatar
yeah if bumper is no conflict with your tunel, just leave it on.
To get my drive line angle right I had to use 2 shims between tranny & rear mount so there was not enough room left between tranny & tunel to keep the rubber top mount on.
I have a 96 Impala SS I converted from A4 to T56. F-body bellhousing/T6 & clutch hydraulics. Just custom clutch pedal assembly & center console insert for the stick. Did it back in '05. LT1 car
I am also doing a LT1/T56 into a 70 Nova. Going carb though on the motor
Attached Thumbnails What is the purpose/function of the T56 Transmission Bumper?-clutch-inst-20-console-2.jpg
Old 01-03-2014, 02:01 PM
elesquan's Avatar
That is too cool!
I am guessing the car is Black? '96 BBB = '96 Big Black Beautiful, or Big Black Beast maybe?
Good luck with the Nova, Always have liked the Novas.
Old 01-03-2014, 03:53 PM
BALLSS's Avatar
BBB is what the trim code is for the "black" ImpalaSS....although as an acronym it has taken on several meanings
Old 01-03-2014, 04:29 PM
elesquan's Avatar
Thanks for educating me. I remember a black SS carting 4 passengers along for the ride kickin *** at an autocross I was at several years ago.
I bet that is a fun car with the 6 speed!
Have a great weekend, and thanks again.
Bruce
Quick Reply: What is the purpose/function of the T56 Transmission Bumper?
