Installing a used Spec3, have questions?
Hey, I am installing a used spec 3 and was wondering if I should clean the clutch disk up with some brake cleaner or not? I know you're not suppose to get the clutch material dirty but its used. What should I do? Also, do you guys know if I will need the spec shim or not?
Thanks for the help
Thanks for the help
Thanks for the help
Thanks for the help
I'm going to reuse my stock flywheel, so it is essential in my opinion.
Why else would they put it in there?
