Will an 08 C6 tr6060 bolt into my 06 Z51
I'm Looking at getting a TR6060 for my 06 z51. Buddy says its completely bolt in.
Can anyone verify this. I don't want to have to buy a bunch of other parts to make this trans work .
Should be as long as it's a standard 27 spline output shaft. The old oil return might be in a slightly different (better) spot on the side of the trans, but you can cut your line and make it work if needed.
