Clutch pedal problem
Old Mar 31, 2014 | 08:50 PM
96LT1Z's Avatar
Default Clutch pedal problem
So a couple days ago my clutch pedal started to stick half way up from the floor. It happens about every other shift. And after I depress the pedal it only comes about half way back up and I have to kick it back up. I haven't noticed any performance differences yet. This car is a 2002 z28. I know it has a after market clutch. Not sure what, I think it is a dual friction clutch. Anyway, suggestions? Maybe I need to bleed the line? Bad throw out bearing? Help!!
Old Mar 31, 2014 | 10:00 PM
Chevyman1968's Avatar
Mine would do somewhat if the same thing. I would pump it and it would get better. I changed the slave and everything worked out just fine. Stay away from the black autozone slaves. GARBAGE. Check out my thread Moody clutch.
Old Mar 31, 2014 | 10:59 PM
chrysler kid's Avatar
Your master cylinder has a secondary seal leak that is letting air into the line while your foot is depressed. My wife's car has the same problem, when I hook up the mityvac to the reservoir it pulls constant air out of the line when the pedal is depressed.
I highly suggest a tick adjustable master, otherwise do not expect the stock master unit from gm or autozone to last more than 2 years at most
