Tick master cylinder
Old 04-21-2014, 05:50 PM
rldevogt's Avatar
Default Tick master cylinder
So I have asked about 1000 questions today during the install of the tick master cylinder. Thanks for all of the help and advice.
If you are doing the install your self and you can't line up the bolts, hook the piston rod up the the clutch pedal and move the pedal I and out to line up the bolts.
Hopefully this little piece of advice helps some one.
Old 04-21-2014, 09:19 PM
!!!FAST!!!'s Avatar
Thanks for the tip. I will be doing mine soon.
Quick Reply: Tick master cylinder
