clutch question?
Old May 4, 2014 | 11:17 AM
solrac7d2's Avatar
Default clutch question?
Hello everyone, i just purchased a 1999 z/28 w/ 93000 miles on it. My clutch pedal feels kind of low but don't feel any slipping. I just ordered a Spec clutch and slave cylinder but was wondering if I should replace the flywheel or could i re-use the one it's got? Thanks in advance.
Old May 4, 2014 | 03:38 PM
Brian100's Avatar
If it shows discoloration when you take it off you just need to take it to a shop that can turn it. If it looks normal it will be sufficient.
Old May 4, 2014 | 04:32 PM
BALLSS's Avatar
you should always resurface or replace FW on a clutch swap. Generally a FW can be resurfaced 3 times if they don't take to much off each time
Old May 5, 2014 | 11:32 AM
SNLPerformance's Avatar
If you resurface the flywheel, make sure you know how much they took off or measure to see if you need to compensate with a shim.
