Stainless Clutch Line for TR6060?
I was looking to buy this McLeod clutch line with its quick disconnect fitting so I can hook up my tranny.
http://www.speedwaymotors.com/T56-Hy...rans,9086.html
However, it appears that the quick disconnect fitting may be different on the TR6060 vs the T56?
Does anyone know where I can get a similar line that will fit with a TR6060? I called SpeedWayMotors to check but they weren't sure.
I think I am in the same boat. Have a tr6060 thats in a 72 camaro but have to by the clutch master and I can't seem to find a line the goes from the master to the quick connect fitting on the tranny. Also didnt realize that these clutch lines were so much. I have called and no one seems to be able to give me a straight answer. I dont even know what the fitting looks like that would go into the quick connect so that makes it a little more difficult. Did you ever find the connection you needed?
