Master cylinder quick disconnect plastic sleeve.
Well, I had to remove my transmission to get the clutch rebuild and I didn't see the plastic sleeve used to disconnect the master cylinder from the slave. Anyone know where I can find one?
Its the white plastic sleeve.
Just like the one located here in this video. It starts at 1:35
Thanks guys in advance.
Yeah, seems you are right. Ended up buying a cheap slave on amazon warehouse to get one.
Also, don't buy the plastic part from this place on ebay, what you get is a similar part but without the lip on the side that lets you pop it off. Seems like the opposite of quick release without it. http://www.ebay.com/itm/180948354321
