Full throttle shift problem.
Old May 20, 2004 | 01:03 PM
ohhiitznik's Avatar
Default Full throttle shift problem.
This only happens when i go 1-2 shift at WOT at 6 grand. I slam the clutch pedal and yank second, its kinda like a grinding vibration, but its only for a split second. I think im like scratching the synchro, how can i stop this? I have a 98 so i need some upgraded hydraulics? Its like tryin to slam into second and the clutch isnt fully disengaged but then it goes in. Its for a split second tho. Its like i push the clutch pedal soo fast and yank that gear so fast that the clutch fluid doesnt disengage the clutch fast enough. I havent done the clutch drill mod yet do you think that would help?
Old May 20, 2004 | 01:47 PM
95_Firehawk_Dude's Avatar
Stock clutch? If not what kind?? What kind of shifter you got in there?
Old May 20, 2004 | 03:16 PM
ohhiitznik's Avatar
stock clutch stock shifter.
Old May 20, 2004 | 03:46 PM
Drivn2Fast's Avatar
syncro is probably worn, mine does the same thing but in 4th gear. Just have to rebuild it sometime and replace the syncros.
