T56 issues
Old Jul 19, 2014 | 09:28 AM
80bu's Avatar
Default T56 issues
I just had my t56 gone thru and I still have the same issue that lead me to pulling the trans in the first place. I also put a new gm slave an master cylinder. I put the car in 1st,2nd or any of the gears and it will go forward and then all the sudden it makes a loud grinding noise and acts like its in neutral. I am new to the ls1 stuff and 6speeds. Any help would be great!!
Old Jul 19, 2014 | 11:28 AM
jmd's Avatar
jmd
Did it ever work as you owned it?
First to check is shifter stops. Back them completely off.
Is the shifter bushing intact and in good shape?
Is it a particular tag no. or from a particular model car?
Old Jul 19, 2014 | 01:51 PM
80bu's Avatar
It worked fine for 1years. Never had any problems with it until now. It's a 1980 Malibu I.did.the swap on.
Old Jul 20, 2014 | 06:00 PM
80bu's Avatar
The slave seems like it working fine as well as the master, not sure where to go from here.
