Another Spec 3 Goes In....
One thing I did notice however is that shifting into 1st and 3rd, I have to "push" the shifter a little harder to get in notched in all the way. It feels a little "mushy" going in.
Is this ok? It doesn't "slippery-slide" right in like it did with the stock clutch. Am I ok? Will this change after the break in period?
BTW, the car had only 11,450 miles on it and the flywheel was in great shape according to my installer, so I didn't change out the flywheel. I also got the new slave. My installer did use the provided shim, and also did the drill mod.
Thanks.
i had that thing in my last cammed car and it was a bitch to drive somtimes.... there is just no excuses for this clutch, it will perform for you
mike
chatter went away completely on my stage 3i after it broke in.
make sure its good and then go launch that bitch off the rev limiter, the clutch will thank you
I hope this doesn't come back to haunt me. He felt that it was not necessary, being that the flywheel had so little miles on it and that there were no scars or hotspots on it.
He even said I had a lot more miles on the clutch, and that I could have run it "into the ground" more before putting the Spec 3 in.
Granted he is a dealership mechanic, so he doesn't do many mod-type installs, but he is their best drivetrain specialist, and has been for 12+ years. So I hope his assessment was accurate....
(Oh and thanks bradah Mark!)
I'm kinda bummed I didn't harp on my friend to resurface the flywheel no matter what. That was the problem with leaving the car with him for a week at the dealership; I wasn't there when he did the changeout.
I guess when I get past 500 miles and it still chatters, we may know it was the flywheel. If that's the case, would it be wise to turn/resurface it then?
'Appreciate the help you guys.....
That could be due to the car only seeing the track 2 times, and it only has 11,5XX miles on it.
Definitely upgrade the slave and do the drill mod however.
Clutch is feeling better every day.
Lucky dog.
If money weren't a problem, I would definitely get a new flywheel.
BTW, just got back from taking the Z out. This clutch feels better everytime I drive it. Not sure about ramming though the gears--->not broken in yet.
