Flywheel MPG
Old Aug 11, 2014 | 05:47 PM
HioSSilver's Avatar
Originally Posted by SNLPerformance
I do have more knowledge, but, at the end of the day it is personal preference.
We can argue this point day in and day out, most people do not want what you're feeding them and when they buy in to what you're saying I wind up getting the angry phone calls.
I still love you though.
I still love you too man
It's not that they don't want it......most simply don't know the difference and go with what erryone else is running. Do you a 25lb~ clutch with reasonable engagement characteristics, reasonable price, advertise the benefits of it and watch it fly off the shelf.
They hear some dumbasses say how hard to drive a light clutch is......which is why I point out the weight of Mustang and Honda clutch/flys . Both have less powerful engines but somehow don't need the inertia to take off......hhhhhmmmmm Think about it.
FYI for some guys that maybe don't know. A aftermarket converter for a auto can be as much as 20lb lighter than stock........there is a reason for that.
Old Aug 11, 2014 | 05:53 PM
SNLPerformance's Avatar
LOL! I think about it daily.
Come work for us a bit and you'd change your mind on what others want and don't.
Converters? Come on man, there is no human error in converter engagement and lock up... apples to chicken nuggets comparison.
Old Aug 11, 2014 | 06:06 PM
HioSSilver's Avatar
I agree on converters......but they don't make them heavier for better low end like some want to believe
I'll do testing for ya on a 25lb clutch....how's that sound? You send them...I'll give you a outside point of view, test them and send them back.
Old Aug 11, 2014 | 06:13 PM
LOL, they do that with the flash on the stall speed (I'm not that versed in converters)...
Already did that.
Old Aug 11, 2014 | 06:17 PM
HioSSilver's Avatar
Was that a custom one off test unit or is it on your site? I would love to see pics of it.
This is the clutch these guys should be buying.
Old Aug 11, 2014 | 06:57 PM
NorthTexasConverter's Avatar
20 lbs? Psh what is this amateur hour? On certain units you can cut the weight by more than half over stock, which is closer to 30+lbs
While a lighter rotating weight is a part of why converters improve performance, part of the reason for a smaller converter is for a higher stall speed. Good luck getting a 4,400 stall out of a stock 4L80E converter.
Preach!
Don't worry, we're 10 minutes down the road from you and we are. Howdy neighbor! Worth noting that I myself am not particularly well versed in clutches/flywheels personally
Old Aug 11, 2014 | 07:13 PM
HioSSilver's Avatar
Lol....good info north.....yea I'm not very well versed on converters. Maybe these guys will see where I'm coming from now.
Old Aug 11, 2014 | 07:29 PM
chrysler kid's Avatar
No but you still think very highly of yourself.
I think the best way to prove your point is by showing rotational inertia mass compared to resistance.
If light weight flywheels were of such benefit they would have been widely used by different manufacturers. You are comparing apples and oranges when looking at different vehicles rotating mass.
If your own theory held true big rigs would come with the lightest weight component available to maximize power and free up the mass added to the weight of the engine by the flywheel spinning.
At the end of the day you are comparing your own custom setup to that of thousands of vehicle dynamic engineers and saying rotational mass creating inertial force has nothing to do with power loss through the drive line.
The starter cranks the flywheel and the engine idles to keep the mass of the flywheel spinning. Because of the inertia of the spinning weight the engine does not labor harder in measurable sense to keep the flywheel turning.
A lightened flywheel however will require more force from the engine to be released as the clutch is disengaged since it does not have the larger inertial mass to absorb friction from the clutch being transferred to the rear wheels.
Old Aug 11, 2014 | 08:30 PM
HioSSilver's Avatar
Dude....wtf are you even talking about? Wtf does big rigs have to do with this?
snl......you probably would not want me working there. As you can tell my customer service wouks suck......lmao
Old Aug 11, 2014 | 08:37 PM
What does you spamming a thread and insulting members have to do with the thread topic? You literally have posted no useful information while demeaning people who have tried to relate relevant information.
Old Aug 12, 2014 | 07:26 AM
HioSSilver's Avatar
Keep thinking that while you bring up big rigs.....lol
Old Aug 12, 2014 | 08:37 AM
  #32
redbird555's Avatar
The big rig thing is really out there.... No one is disputing that a larger clutch/fly will have more inertia. Comparing a 20ton big rig to a 3400lb car is a BIG stretch the extra inertia there is much more crucial. A lighter assembly is a SMALL bit trickier to drive but its a much smaller scale than something weighs 30,000 lbs.
The inertia of the flywheel helps the motor keep spinning and makes launching easier. HOWEVER if you can launch the car which with some practice is very easy then the are no downfalls, only gains. After the initial engagement the heavier assembly and lighter assembly are both spinning and fully engaged with the engine. To spin up ie. accelerate the mass and thus accelerate the car the engine needs to overcome the heavier moment of inertia which will take more power and time than with the lighter assembly. Which is dyno gains are common with lighter setups. By your big rig logic why dont we just keep the 70lb clutch that comes in the cts-v? That would store even more inertia and get an even better launch....Except on those cars a light clutch is one of the first mods and also best performance rewarding ones you can do.
Go ahead tell the svt engineers that their stock aluminum flywheel that weighs 13lbs and the whole clutch assembly that weighs under 40 in the 3800 lb 03-04 cobra will never work and performance will suffer.... Except for the fact they did it 10 years ago and it works fine.
Old Aug 12, 2014 | 02:12 PM
  #33
Custom one off, yes. Was it a ***** to drive daily? Not really. The problem is you did have to slip it quite a bit to get the car rolling and when doing so puts unwanted heat into the friction. The car suffered tremendously on the 60' times as well. Obviously a C5 car you must ride the hell out of the clutch and depend on it to get the car out of the whole...
That's good to hear! I'll teach you about flywheels/clutches if you ever need it.
LOL, you're a bit coarse as an individual. I get you're passionate about what you believe, but I can assure you that what I'm telling you is the truth. The masses do not want uber lightweight clutches.
  #34
I think we've all shat in this thread enough, sorry about that OP.
Old Aug 12, 2014 | 04:11 PM
  #35
HioSSilver's Avatar
Most don't know or realize this......but they will continue to argue drivability
So SNL......you think the masses of 03/04 cobro is gonna be happy with your 28lb flywheel???.....lmao I mean that alone pretty much ends the thread.......There is no reason for a 50+lb clutch fly in these cars. It's part of the reason why you see 13'sec bolt-on fcars at the track.
Old Aug 12, 2014 | 04:29 PM
  #36
So now you're going to compare a PD car to a NA car? A PD car doesn't need the inertia off the line as the blower and low end torque help that.
You're all over the place. Gear ratios, weight of the car, torque the engine produces, etc. all play a factor in this. Give me apples to apples comparisons of a large group of people with the same car in all the same given scenarios, then I'll buy your information. I've done that with the clutch shop, that's where I derive my information from.
Not to mention, nobody likes Mustangs or Hondas. LOL
Old Aug 12, 2014 | 05:40 PM
  #37
BALLSS's Avatar
agree...OP has not been back on his thread since his original ?
but Hio wants to keep beating his dead horse Silver...
Old Aug 12, 2014 | 05:47 PM
  #38
LOL
Old Aug 13, 2014 | 12:07 AM
  #39
redbird555's Avatar
Who likes mustangs???? Errhhhhh..... lol
however the blower ont he cobra or any car for that matter makes no difference. at low takeoff and light throttle the blower is doing little to nothing. boost on roots or twin screw blowers is only made when the throttle is stabbed open at cruise and light throttle the engine will stay in no boost or slightly in vacuum
Old Aug 13, 2014 | 06:48 AM
  #40
HioSSilver's Avatar
You got to it before me red....I was gonna say the same same thing. But I will add to it. W/o the being in boost the 4.6 is a 8.5 compression anemic turd. They seem to have no problem with drivability with a 38lb clutch.......atleast my termi notch don't
