Lt1 T-56 to Ls1
Lt1 T-56 to Ls1
I've done some research on converting an Lt1 style T56 to and LS1. Im thinking about swapping a T-56 into my f body. From what I understand in order to convert the t56 you have to change the input shaft and front cover. Also have to have a different bell housing. With the conversion will this still allow you to run a stock length draft shaft and a ls1 style clutch.
The Car: 95 f body lsx/4ld0E
