Identifying 6 speeds
Old May 23, 2004 | 12:15 AM
69txcamaro's Avatar
Default Identifying 6 speeds
I found a good deal on a 6 speed and I was just wondering how I can identify what year model camaro the 6 speed came out of...... It is supposed to be out of a 2001 or 2002 Camaro.... Is there anyway I can tell? Thanks in advance.......
Old May 27, 2004 | 02:07 PM
ohhiitznik's Avatar
get a 98 or earlier... the 98 is the only borg werner tranny for the ls1 i believe.
Old May 28, 2004 | 09:12 AM
hourang's Avatar
yes sir
Old May 28, 2004 | 11:14 AM
ohhiitznik's Avatar
Originally Posted by hourang
yes sir
You always notice how guys dont have problems with there lt1 6 speed trannies! cuz they borg werner. the tremec t56 isnt as durable as the borg. B&W all the way man.
Old May 28, 2004 | 05:55 PM
TransAm52804's Avatar
Borg Werner 6-speeds. Mmmmmmm.
Old May 29, 2004 | 11:35 AM
SStolen's Avatar
I've talked to numerous tranny places and they say they are the same thing inside and out. D&D laughed when I said they were different. The LT1's don't break because they are only putting down 255 focking rwhp.
Old May 29, 2004 | 11:55 AM
kossuth's Avatar
LOL That isn't the reason at all. The LS1 hydralics are the causes of the problems. For goodness sakes the viper uses a unit similar to the fbody T56 differences are minor and a viper has alot more go stock vs stock than a fbody.
Old May 29, 2004 | 03:37 PM
ta12sec's Avatar
the lt1s and ls1s use difrent input shafts so make sure you get a ls1 b&w
Old May 30, 2004 | 09:19 PM
jmd's Avatar
jmd
Agreed; the "Tremec T56's suck" rumour needs laid to rest.
The fork release setup on the 93-97 f-bodies just flat out works good. The throwout on the LS1's doesn't. Without further detail, that's the jist of things
