Richmond 4+1 too much hassel/cost?
I am starting my lq4 swap into my Javelin and I will be running a manual transmission. I currently have a Richmond 4+1 with the long shifter I was going to use when I was going to run a gen I motor. I have a Lakewood scattershield for the sbc I was going to run along with the matching centerforve clutch. After doing some reading it appears I will need a different bell, clutch, and flywheel. Would it make more sense to run a proper t56? I was hoping I could use what I already own but it doesn't seem like the sbc bell will work in this application. I already planned on running a hydraulic throw out bearing. Not sure if that changes application here. Any advice would be appreciated.
