Bleeding the clutch
Old May 25, 2004 | 06:46 PM
ss1le02's Avatar
Default Bleeding the clutch
Do I disconnect the hydraulic line on the tranny and have someone pump the clutch pedal until all the air bubbles escape? Keeping in mind to have the master cylinder resevoir full at all times.
Old May 25, 2004 | 07:19 PM
Camaroholic's Avatar
No, you don't disconnect the line. Pump the pedal a few times, hold down the clutch pedal, have someone crack the bleeder valve (it's above where the line goes in to the trans, with a 7/16" socket), close the bleeder, then pull the clutch pedal up. Pump the clutch a bunch, then repeat. Check the fluid after every 2-3 "cracks" of the valve.
Old May 25, 2004 | 11:42 PM
ss1le02's Avatar
Thanks for the info. I pulled my engine and tranny when I fried the motor. Everythings back in and runs great. The only problem I'm having is shifting it into reverse. I really have to push it far to the right. It wasn't like this before the engine removal and replacement. I'm thinking that it needs to be bled.
Old May 26, 2004 | 09:04 AM
Are you having to push really hard on the shifter to get it in to reverse / to the right?
If so, then odds are that the electrical connector for the reverse lockout solenoid isn't hooked up properly, or a pin may have gotten bent or pushed out. Check it out. It's on the passenger's side of the trans, up near the shifter base. Check the pins inside the solenoid connector, and the pins on the wiring harness side.
Old May 26, 2004 | 11:44 PM
ss1le02's Avatar
Yes I'm having to push really hard and up to the right. I had it on the dyno today and looked at it. It seemed to be hooked up. However, I didn't disconnect it and look at it carefully.
