XTR Chromoly Flywheels
Old Dec 9, 2014 | 09:00 PM
slow ride 02's Avatar
Default XTR Chromoly Flywheels
Does any one know about these flywheels on ebay?
XTR Racing X-Lite Lightweight Chromoly Flywheels are made from 4140 one-piece billet chromoly steel. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel which has the possibility of separating from the flywheel. All XTR Racing Chromoly flywheels have passed engineering tests to 12,000 rpm. After professionally installed the flywheel requires a 500 mile break-in period.
Ultra heavy-duty and weighs only 15.45 lbs (stock flywheel weighs 24 lbs)
http://www.ebay.com/itm/XTR-CHROMOLY...EOIBSA:US:3160
Old Dec 13, 2014 | 12:21 AM
ls1 1990 VN's Avatar
What's to break in on a flywheel....next they will be breaking in wheel nuts!
