chatter when not engaged
The clutch is dis-engaged when the pedal is down. And is engaged with the pedal is up. What you describe could be one of the transmission bearings. At the same time it could also just be the typical chatter heard on most T56's from input shaft neutral rollover. If you don't hear it at all with the trans in gear and moving then it's probably nothing. If it goes away by 2,000 rpm that's still typical of input shaft rollover where the gears seat together better. If it gets louder above 2,000 it opens up the potential for bearing issues. That said, my car has similar neutral/idle chatter that goes away with the pedal down. It's also there in gear at higher rpms.
I took a few simple steps to quiet my after market Hurst shifter and the noises were reduced quite a bit. I took it to a well-respected performance transmission shop and the owner didn't feel it was a bearing problem. T56 rattles can be hard to nail down. Most are probably normal. If this is a sudden change then I'd look for something having become loose. Could be anything from something under the car, inside the trans, the shifter, etc.
when you "press down" on the clutch the clutch is "not engaged"......and you say noise (chatter) happens when "not engaged" but goes away when you "push down" pedal which also means "clutch not engaged"...conflicting statement
If this has gotten worse lately then look into the shifter. Anything could have come loose in there. And there are numerous ways to help silence a "hard" shifter. The factory shifters had a bushing between the upper and lower shifter shafts that dampened a lot of the noise. Shifter ***** can be noisy all by themselves. I made a post on this last year about "silencing the T56 rattles." Lots of information there that I found from surfing numerous auto blogs.
If this noise has always been present I wouldn't worry about it unless it started getting a lot worse. A lot of people don't even know they have this noise. With the radio on or the windows down it's often drowned out. First time I ever heard it in a T56 I thought the dash fan was running.
http://rsgear.com/articles/2008_08.pdf
I bought a new T56 in 05 from D&D and initial start up I about craped my pants. Found out is was normal. In my case it has gone away after putting some miles on it and now about 10 years later it is very quiet after several clutch swaps and a few motors works like a charm
