Truth about the 1LE mount
Old May 29, 2004 | 11:52 AM
demonspeed's Avatar
It's not mine! woo hoo!
Default Truth about the 1LE mount
I did a search, and I'm a little confused. I need a new mount, but I'm NOT considering a poly mount. So the 1LE seems to be the one to go with.
What i've gathered is the 1LE mount is discontinued. Others say it's stock on 01 and 02's. Others say it's stock 00-02.
What is the deal? Do I go to the dealer and say I want a stock mount for a 2001 or will a stock 00 mount be a 1LE too? Will a 01 mount even fit on my 00?
Old May 29, 2004 | 07:40 PM
black_z's Avatar
I am in the same situation as you man, but I am strongly considering a prothane mount. From my research ive found its the same height as stock, and no trimming has to be done. It also seems to "break in" after a little bit of driving.
Old May 29, 2004 | 11:33 PM
demonspeed's Avatar
I guess I might have to as well... Who sells prothane stuff anyway?
Old May 30, 2004 | 09:13 AM
black_z's Avatar
Thunderracing has it, as well as speed inc. It took me a while to find them, but they are there. Look for bushings in the menus and you will find them.
Old May 31, 2004 | 12:51 PM
ZigZagZ's Avatar
So does anyone have the answer to DemonSpeeds question? Is there a difference between the 1LE mount, and the stock unit from 00'-02' ?
Old May 31, 2004 | 02:20 PM
demonspeed's Avatar
yeah... I still would like an answer...
Old May 31, 2004 | 07:17 PM
NastySSoo's Avatar
To the best of my knowledge the 00-02 have the 1LE. I still have my original mount with over 1300 passes at the track and 79k. If and when I break it I will definately get a new one from GM. Im launching with ET streets and a iron disc clutch.My.02
Old May 31, 2004 | 07:38 PM
demonspeed's Avatar
I think i'll just go to the dealer and see if the part numbers are different between the years.
Old Jun 4, 2004 | 10:38 PM
98_1LE's Avatar
My '01 did not have a 1LE mount stock. I have the original, worn, mount from my '98, and beleive it to be the real deal.
Old Jun 5, 2004 | 12:20 AM
DrkPhx's Avatar
The "real" 1LE mount is not made any more. I believe it was last put on 00 models. When you give a GM dealer the part number it will cross-reference to the universal mount.
Old Jun 5, 2004 | 12:29 AM
Orange Peel's Avatar
And the stock mounts cost like $70, f'ing outrageous!!!!! But they work, quiet and hold up to some abuse, I am still on my original mount, 83k miles, but I can tell it's starting to wear out, little too bouncy and loose feeling. I don't want the poly for the noise, but I may have to bite the bullet and get one. It's $70 vs $25, big difference!
Old Sep 30, 2004 | 07:00 PM
Keenov's Avatar
The poly is good, for the first 300 miles. After a few passes it starts to vibrate like a womens play toy. Even if you go slow. The exhaust note even changed with this mount being in the car. I am probably going to get a stock mount when I put in the Spec 3.
Old Sep 30, 2004 | 07:08 PM
DanZ28's Avatar
I ordered a 1LE mount from SLP back a year or two ago and it looks nothing like my stock 00' mount does. The material is stiffer and the Stud mounting to the crossmember is different..
Dan
Old Oct 1, 2004 | 08:31 AM
Stew w/92&00's Avatar
I like my prothane mount.....
