Hydraulic lag??
Spec stage 2
Spec Billet flywheel
O1+ master cylinder
TO bearing
01+ Slave Cylinder
Not sure exactly how to describe this but basically at a stop I'll push the clutch in and push the stick forward towards first, and there's about a 2 second delay before it will let it in, if I push to hard to force it, it grinds! Just seems like the fluid takes to long to get there, also have the drill mod done... Background on the car, was making mid 300's to the wheel when I installed the clutch etc but since have gone turbo and I'm ~550 whp, have I possibly wore out the stage 2 for that power range or does it sound like I just have a hydraulic issue? Not sure where to start looking as far as which part could be the culprit. Thanks for any input
Also, LOL on your sig quote
