Clutch won't disengage
Old May 5, 2021 | 11:01 PM
Beatlepistol's Avatar
I am one of those people I hate on these forms. (I forgot my password) and didn't tell the solution. The problem was oil leaking from the missing "freeze plug" in the back of the crank shaft. It got knocked out by a mechanic replacing the the pilot bushing using the "fill the hole with grease and use a drift to force the bushing out method" that works fine for older stuff but not LS engines. This happened before I owned the car! (I found the receipt in the glove box) I removed the rear cover after taking the trans out. I found the mangled "plug" looked like a freeze plug. The oil swelled the clutch's friction material and would not let the clutch disengage. I replaced the plug in the crank using JB weld for good measure. Replaced the clutch with a cheap O'Reilly brand (DON'T DO THAT it slips sometimes). And all is well years later. Hope this helps anyone who searches.
