T56 Magnum/6.0 what clutch do I use?
Hi there, I'm shopping for a clutch for a future project. It's an LY6 6.0 that I have a T56 Magnum for and have a Quicktime Rm-8020 bellhousing on the way. I'm wondering what application clutch I need to buy to mate this up. I've think I've read both 2010+ Camaro and also 4th gen f body? Thanks in advance for the help.
If this is a relatively mild engine then the LS7 clutch and flywheel is a nice combination. As I said, your choices are almost unlimited.
Andrew
Your choices are wide open. Any LS flywheel with a 6 bolt pattern will work, then you watch the clutch to the flywheel.
Andrew
Andrew
Andrew
a monster lt1 series twin is your best bet and they have the best customer service of anyone.
http://monsterclutches.com/
Andrew
