Leaving nice Patch = Messed up clutch
As far as not being able to do a burnout, that's silly. Of course you can...
If nothing got in there, them maybe there was a chunk of material in the disk itself? The last clutch I had in my car (Centerforce) had actually turned the flywheel blue and had heat checks ever 1/4". It never welded itself to the flywheel.
Here is a pic of the pressure plate.
The reason it did what it did is heat, when it's slipped excessively, or, it slips itself the heat builds up and doesn't dissipate in the friction. This causes the friction to liquefy and essentially weld itself to the pressure plate.
This is very common in aggressive setups. That said, I've got much better options these days.
From what you are stating, either he cannot do burnouts, he does not know how to drive a stick, or this clutch is either defective or a bad design.
The flywheel has some heat checks, but I have seen a lot worse and the clutch did not weld itself. Am I missing something?
What I do know is we stopped selling those because the price for manufacturing that friction became so expensive it would have made a $1000+ single disc clutch, which isn't going to work in the market. The friction itself is fantastic and very very smooth. As with any aggressive metallic based friction, if you get it hot enough it will liquefy and adhere just like this did. It doesn't make it a bad friction, but I would agree that this isn't the unit I'd have recommended for a cam only Fbody.
