Anyone here hate the MGW?
Gearheads install aftermarket shifters, sacrificing those attributes for more precise, direct feel with the accompanying increase in vibration/noise.
Find it amusing those same people then complain about the NVH.
The only real difference between after market shifters is lever ratio and side spring pressure. Unless the plastic cup is swapped out to brass, what exactly are you saying "brakes in"?
The perceived notchy feel IMO is a result of eliminating the rubber isolation and/or the reduced lever travel, nothing internal to the transmission changed, which has a greater impact on shift "feel"; ie the tr6060/magnum revisions.
too many "street cars" and people complaining about how hard the centering spring is.
i havent missed 3rd yet. dont even have to try to hit third, just slam it forward and it goes in.
So they are selling a shifter, largely aimed at those with intentions of racing, with 1/4 mile being the main use...especially noting the 2-3 shift aspect.
And some people are saying it might take 6 months or 1000 miles before it's broken in ?
That's an awful lot of 1/4 mile passes before the shifter might be any use.
And you deem that normal ?
I've never used one, and I'm sure strong centre springs are a good thing. Externally it looks "nice" too and as others say there are a lot of fanboy's for the product.
But certainly comments in this thread especially about "break in"...really dont do the product any favours.
Isnt a hope in hell I'd buy any shifter if someone said I needed to use it for 6 months or 1k miles before it would work properly. That's just mental.
FWIW I'd also like a shifter with a strong centre spring. But of the Pro5, stock Camaro and B&M, of all of those the stock shifter has the strongest spring from the left side to centre of gate.
The design of the MGW put me off, as the tall body looks like it would have a very very short throw with a high leverage point, not what I wanted.
I had a 5-speed 3rd gen that shifted like a dream, and it was because the guy I bought it off of ran a transmission shop.
My 4th gen's 6-speed has been a disaster since day one (whoever owned this car previously needs to fall off a ledge). The Hurst billet/plus helped mitigate some of it, but now it's in a crate to finally get rebuilt. I bet I get it back and after driving it a bit the thing shifts like my 3rd-gen did.
First of all I love my MGW. I looked on here before I bought a short throw and noticed that the overwhelming majority said MGW ftw. All I knew is that the stock **** had to go. Same thing with the Tick Master cylinder. Everyone said get it.
So I bought a wilwood master cylinder for my clutch and found out the hard way that the tick unit was superior. That being said, I did not want to make the same mistake twice because obviously the majority of the people on here are not morons.
With the logic behind purchasing now brought to the light, I want to move on to the actual product.
The shifter itself was beautiful and was a shame that it was going to be covered up. I did noticed that the gates were going to obviously going to be moved to the driver side of the car just by looking at it. However, if you never saw the shifter outside of the car or without the boot on, you'd have no idea. I Have no recollection of where the stock placement of the gates were. Having had it for about 8 months now, I have notices that there are some things that are characteristic of the shifter and then there are things that are characteristic of hydraulics and transmission wear. 5th, 6th, and reverse for that matter are greatly affected by the quality of bleeding that was done on the clutch and the wear on your syncros. My stock hurst shifter gave me issues going into these gears and changing to the MGW did not rectify these issues. What rectified these issues was a clutch overhaul and a Tick master cylinder along with new hydraulics. once that was done, each gear engaged like butter. I also noticed that rev-matching gears helped tremendously with 5th gear down shifts while moving.
I did not notice it ever loosening up. I did notice a learning curve though. At first I took off from 3rd several times, before I made sure that I moved it that little bit it needs to engage 1st instead. Once that learning curve is over, the whole car is more fun to drive because of that piece. Missing gears is just not an option almost. Power-shifting is a breeze. Argue where you may but the closer gates mean faster shift times because with any given speed (ie the maximum speed you can shift), if you minimize the distance then your time will also be minimized.
Shifter feel will always be opinionated, however quality, craftsmanship, and how short the throws are will forever be objective. IMO the MGW is a great first mod and if I ever buy any other T-56 or TR-6060 car, this will likely be my first mod.
All of the shifter's shortcomings are what make it great for me. As this is installed in my daily driver, I have quickly become accustomed to those shortcomings so that now they are virtues. There is 0 play in the shifter, for example, so everytime I drive another standard car, it becomes obvious that there is play in it. It was stiff at first and it does take some gettting used to but IMO it was worth taking off 2-3 times in 3rd gear from a stop.
The funny thing about opinions is they're only opinions, the world won't stop rotation whether or not you have a MGW shifter. I've had good luck with both the Pro 5.0 which actually wore out, and my current Hurst Billet Plus which I like even better.
Am I crazy or are there others that don't love this shifter?
