lt1-s with or without tick master???
Old May 21, 2015 | 11:24 PM
swey00's Avatar
Question lt1-s with or without tick master???
I am putting a ls3/t56/awd in my 72 blazer. I have read different reports on whether I should use a tick master with the lt1-s clutch. Basically I just need to know if I should use the tick or not? It has a pretty heavy clutch in it right now.
thanks
Old May 22, 2015 | 02:37 PM
Darth_V8r's Avatar
Moderator
I would ALWAYS use the tick master. After you install, you need to sneak up on the correct adjustment length.
Old May 23, 2015 | 02:45 PM
Rob WS6's Avatar
Some twin disks arent recommended to use with an aftermarket large bore master cylinder as they move too much fluid and make the engagement window very small. I had this problem with my Ram 9.5 twin and a Tick master. At the recommendation of Tick, I swapped my master cylinder down to a 3/4" bore and its perfect now. Im not sure if the LT1-S requires this, but you can order them this way from Tick, give them a call!
Old May 24, 2015 | 12:46 AM
quiet_storm98's Avatar
Im running a tick master with my lt1-s only because i already had it. Even with the tick master which increases pedal effort some it drives great and the engagement window is still very good
Old May 27, 2015 | 02:18 PM
SNLPerformance's Avatar
thanks
The choice is up to you, either master will work with the LT1-S.
Just keep in mind that if you use the Tick master, it will increase pedal effort and shrink the engagement window.
Give us a call if you want to go over details.
Old May 27, 2015 | 03:14 PM
elephantrider's Avatar
i'm running a tick and a lt1-s in my goat. if you go with the tick,
be damn sure you start the adjustment with the clutch pedal as
close to the firewall as possible, or you will damage the pressure
plate.
my engagement window is roughly 1/3 of what it was with the ls7
clutch and factory master.
one of THEE best mods i've done to the car to date.
