Manual transmissions
Thanks in advance
Dave
There is some issues with early 6.0L truck engines as they had a crank with a different offset, but otherwise, all 6 bolt Gen III and Gen IV have the same flywheel pattern. There are two styles of flywheel, the LS1/6 flat style and the LS2/7 stepped style. Either will bolt to the crank, but you have to run the appropriate clutch to match whatever style of flywheel you choose.
Hope that makes sense.
Andrew
Andrew
