Let's talk about lightweight clutch/Flywheel combo's
#262
Moderator
Received 1,836 Likes
Either everyone around here with an RPS triple cant install a clutch or they are junk. I'm not impressed with the multiple failures I have seen from them. If you want a carbon triple why not just go straight to Tilton? They invented it after all. I don't get why import guys can go fast with these little Tilton clutches and its something of a black art to domestics? They do the same thing we do, build all the boost off the line and send it.
Mine don't have any springs though other than the PP itself.
I agree about the domestic guys. If it works for a 2.0 Honda should be fine on a LS anything.
#263
Is that specific to the triple disc? I've been running the RPS twin billet for two years now and been extremely happy with it.
That's not a coyote stock car running 9.4s
Tilton ftw!
What it comes down to is there is more than one way to skin a cat. Weedy is from the furd world. Lets face it......their engines leave something to be desired. So they rely on inertia to get down the track. Not the first time I've seen a furd guy claim the heavier clutch is faster. It narrows up their power band to the point the clutch is not coupled much except for a x hundred rpm in each gear. It's almost a tq converter.
Now hopefully at some point this year I'll get to try it both ways. But there is not much doubt with a engine willing to accelerate which way will work the best. Because all that heat weedy is talking about is also wasted energy. That energy could be used to propel the car forward with a lighter more efficient set up
Tilton ftw!
I agree heat energy from slipping is indeed wasted energy. Seems like 6 of one half dozen of another. The funny part is we've seen cars go faster turning over the slick rather then dead hooking, wasted energy and all. If it was a radial then I could understand but different strokes.
I still don't get that even if his 10" single somehow does manage to handle a season in a 1000+whp 4k lb car slipping off the line every pass. How the 10" single somehow handles heat any better then a triple disk that has more surface area and also has full face solid hub iron disks?
Its really not hard to determine overall capacity. Get the inner and outer radius of the disks along with the friction coefficient and pressure plate clamping force and you calculate the torque rating of each clutch. Since Tilton publishes everything except friction from what I've seen you can work it for the variable. Seems like at least a 1200 rating from these 7.25 units?
#264
Coyote Stock car with factory sealed engine running at an all motor event. I am using the Coyote cars here as an example of the efficiency that can be had from a "heavy" 10" single disc clutch.
#265
It's about how much energy a given clutch can absorb in a short period of time without overheating. In that regard more mass is better. Surface area exposed to air means little, as energy is being absorbed at a faster rate than the surface area can transfer it away.
#266
A 10" Softloc style single has about 25% more friction surface area than a 7" twin. My clutch is even bigger @ 10.5".
You keep dodging the answers on what it can actually hold. I've seen multiple softlocs used, but almost always in lighter cars, heavier turbos cars went faster swapping to a normal clutch.
Has anyone here with a 7.25 triple over heated it?
Thats not a good example because it's a sub 3100lb car not making any power, that's a perfect world for clutch longevity not the abuse we subject them too with much heavier cars making almost 3x as much power.
#267
I just looked that car up, Carlos Sobrino. Car is 2550lbs so its not Coyote stock legal. Plus that car is running a Gforce G101A trans so hardly a comparison to a stock tremec. I dont get the point of comparing a flyweight race car with a race car 4 speed trans to a bunch of heavy 6 speed street cars?
#268
Yes the triple. Some of it may stem from slave cylinder selection and not having room for clutch wear, others might be from over extending the pressure plate and not using a pedal stop but I cant confirm. After setting up an aftermarket slave I would never go back to stock junk and a pedal stop is easy to setup. However I assume anyone spending $3500+ on a clutch would set it up properly?
lol So your saying weedy hasn't felt 25PSI before the 60'? Damn you torque! So that clutch tamer with an LS on 35PSI is just going to result in a burnt disk. I'm used to letting off at the 1/8th and coasting to faster then 137MPH and hes thinks that MPH is somehow impressive in a car that's almost 2000lbs lighter.
But yes.....coyote stock cars are very efficient. They are full on race cars. The fast ones are the best if the best **** in then with 24xxlb or less curb weights and weight added to make weight.
I dig the coyote stock stuff. But it's not comparable to what most of us is doin.
#269
The point of my responses to this thread is that it's possible to produce more net power in a given time frame by using clutch slip to your advantage. That requires a clutch that can handle some slipping without damage, which generally means if you are making a lot of power you may need a heavier clutch that can tolerate the slipping. Know of any other way to squeeze 9.40 et's out of 137mph power? I don't see anyone on the fastest 6spd list doing it yet.
#270
#274
You would need a pulling truck clutch to hold 1k hp and move 4k lbs to slip it like you want. Of which btw are8some big hunk of cast iron lie the stock junk is.
You're also trying to compare these full on race cars to street cars. I'll take the lighter clutch between those 2 situations.
#278
There is plenty of evidence out there showing that yes lighter clutches do accelerate better weedy. It's kind of a no brainer. Especially with the over weight gm clutches.
Scotty's results aren't really whete they should be yet. Anyone trapping 118 in a fbo ls6 z06 should trade it iff on a prius to save the gasoline for those if us that know wtf we're doin.
I've seen stock c5z go 118.
#279
Moderator
I will say a lesson learned on my part - the lighter clutch seems to like a smaller master to help with slipping at launch vs the larger master I had before. I lost engagement window width with the lighter clutch.
#280
Well...not really do to lighter clutch. More of the design of the clutch and the fact that a clutch with grippier material will act like the window is smaller.
On a clutch like mine and scottys the length of the springs are much shorter also. Further reducing the amount the hydraulic release bearing has to travel for engagement.
It's not really a weight thing.
