t56 to transfer case.
any help is much appreciated.
The lockring grooves (for GTO reluctor ring) are a point of weakness due to sharp transitions in the metal, but you're not going to do anything about that at this point.
It can be cut; you want to make sure the input gear in the t-case is mated to good splines. But, make sure there's a tangible benefit to it. A trans. that takes an "off the shelf" mainshaft and has a slightly shorter external shift rail is preferable to the alternative.
