Difference between Monster LT1-S,SC and R
Old Dec 30, 2015 | 11:44 AM
eb02z06's Avatar
Default Difference between Monster LT1-S,SC and R
Besides the obvious power capability what are the differences in friction materials pedal effort and streetability.
I am torn between the LT1-S or SC versus the Mcleod RXT. I need a daily driver clutch that I can also track-but slip out of the hole on the launch.
Something that can be rebuilt on a yearly basis without breaking the bank is a plus too!
Old Jan 7, 2016 | 12:13 PM
slowride's Avatar
I believe S is the stock organic c7 disk, SC is miba like a rxt and the R is sintered iron. The good thing about those plates is the SAC adjusts to wear keeping full pressure on the disks till the end of service life.
Old Jan 7, 2016 | 03:57 PM
SNLPerformance's Avatar
Give us a shout and we can go over details.
(817-750-2000, or Email Jacob@monsterclutches.com)
Old Jan 7, 2016 | 04:30 PM
stevieturbo's Avatar
If you're looking to slip it hard on launch, organic materials are out
You're into puck style metallic discs or carbon
For street use carbon will give you the smoothness of an organic disc.
Puck style metallic discs are very good these days too, and perfectly doable for a daily driver. Although if you see a lot of traffic stop/start, I'd try for different options.
Old Jan 7, 2016 | 04:36 PM
Not true on the new organic frictions... we use the newer organic stuff in our S units and they take heat like a champ and keep on ticking. I've literally rode the **** out of a clutch in a 500 rwhp + car, to the point smoke was pouring from under the car... then launched it and ripped through the gears at Ennis. We did this repeatedly, all day long, and it never let go. We pulled it at the shop later and found the friction was still in great shape...
The newer stuff has come a long, long way - carbon clutches are over-priced for what most need and are just not necessary any longer.
Old Jan 7, 2016 | 04:41 PM
You've definitely more experience than me.
But 500hp is a lot less than the 800+ Arun is using assuming it is the car in his sig.
If the organic can hold the launches good, then happy days.
Old Jan 7, 2016 | 04:44 PM
We have a triple S that's organic and holds just north of 1000 rwhp... and can be slipped like a mother.
Happy days indeed!
Old Jan 13, 2016 | 09:11 AM
eb02z06's Avatar
I've had so much luck with the LS7 that im going to go with the LT1-S for next season-I'll try it out-it's not that expensive. Cause after next season I'm going auto.
