low pedal after monster clutch install
I have a 98 camaro that i recently put in a monster stage 2 and new slave cylinder after i bled the system the pedal disengages very close to the floor. Im leaning towards needing a new master cylinder but wanted someone elses opinion thanks
Ive only had the car a month now and the clutch was bad when i got the car so it, the master cylinder felt ok but 5he clutch being bad it was to hard to determine the actual condition of the master cylinder but it wasnt disengaging an inch from the floor before the clutch install
This sounds like a case of the master not moving enough fluid to actuate the clutch.
Here is a link to our master kit should you want it. http://www.tickperformance.com/tick-...-firebird-ls1/
Moderator
Received 1,836 Likes
I'm a huge fan of the tick master, and if you are going to replace the master, you would do well with it.
That said - did you measure for a slave shim? If you need a shim and don't install one, the tick master CAN overextend the slave.
Not to sound like a nutswinger, but the Tick MC IMO is the end all solution. I tried brand new factory hydraulics (on my Z06) and they did NOTHING for me. From there, I assumed the weak dick adjustable pressure plate was to blame so I installed a Spec Stage 1 clutch with aluminum fw/pp and my clutch pedal got worse! I must say though that dropping 20# of rotational mass off of that made a significant difference in accleleration. Finally, I bought the Tick MC and all of a sudden I could smash gears all day every day. I'm 100% sold on their clutch master cylinders, absolutely legit.
