Is this fixable?
Is this weldable? Should I be worried about anything immediately behind this part? it's on the bottom back of the case, I removed the bolt from the hole pictured to see the extent of the damage.
Well, that isnt an easy proposition.
If you remove it and clean it etc then yes it would be easily weldable.
I think it'll hold.
Luckily I have a new issue to tackle. For some reason the slave cylinder is leaking inside the box now. It has never even seen pressure as I haven't bled the line fully yet. This is the second slave cylinder already as the first one leaked too. What is going on?
I think it'll hold.
If there is a better brand, please let me know, next time i change this out better be my last.
I ordered a genuine OEM (AP brand) slave cylinder. $170 later I should have it in 2 days. Not looking forward to pulling the trans to do this. I have zero room to work with and the sucker is heavy. But this better be the last time I have to pull this. 2 faulty LUK slave cylinders in a row is unacceptable. It's possible I'm doing something wrong but I can't for the life of me figure out what I could have done wrong.
Draper 53095 150 kg Floor Transmission Jack: Amazon.co.uk: Car & Motorbike
http://m.harborfreight.com/450-lb-ca...not%20provided
To change the slave, you could probably get away with just dropping it a bit ( remove drivesahft/shifter etc of course ) and just roll the trans back, unbolt the slave, slide a now one on and slide trans back across and into the bellhousing without even dropping trans to floor level.
It's my mistake for trying to over engineer it, like a stupid engineer. I'll learn from it, fix it, and get it all back together. I have a wedding to attend tomorrow so I'll get the trans back in the car on Sunday. One step closer to finishing this project.
The solvents are volatile, but its nothing like a real explosive (like flash powder or acetone peroxide) I think if I wasn't wearing a welding mask, it would have singed my hair who knows. But it wasn't that bad
