T-56 Decelerating Noise in 5th-6th
Hello all.
Long time lurker here, 1st post..
I have an LS FD Rx7
I am having a concerning issue with my trans, & I'm just trying to gauge possible culprits.
When I am decelerating at highway speeds, (low speeds in high gears too (mainly 5th and 6th gear)) I hear a nasty noise coming from the trans. Feels like its directly at the rear of the trans.
Its a sort of grindy, whiny, slop noise...
The car drives, shifts, functions, moves perfectly, (in low gears you would never know somethings wrong) but in higher gears decelerating I hear it quite loud.. Its hard to tell if it does it while accelerating, over engine noise..
I just had the U joints replaced hoping that may have been it, the car is a bit smoother, and less jerky but its irrelevant.
I couldn't find anything online too definitive, or with exact relevant symptoms with other people, so figured id ask here.
What I can gather is possible output shaft, miss-shim, or other worn bearings...
I'm not overly transmission literate, But I'm sure I will be after this..
Its going to be a few weeks before I can have the means to pull the tranny.
Thank you,
I have an LS FD Rx7
Thank you,
