T56 Sudenly Hard To Get Every Gear!
Old 05-10-2016 | 08:10 PM
onroadyno's Avatar
Default T56 Sudenly Hard To Get Every Gear!
My 2003 LS1 T56 (Holden Commodore, Australian) had the clutch, pressure plate, flywheel and slave changed 5000km ago with a genuine kit.
The clutch will not fully disengage, so I cannot change gears and have to "key" the car to move.
I replaced the master cylinder and have the same problem.
After a bleed the clutch works a few times then reverts back to not disengaging and this has been proven many times.
The gearbox is now out and clutch assembly looks like new.
Can anyone with a similar experience please help.
Thankyou
Old 05-13-2016 | 08:21 PM
Project GatTagO's Avatar
Sounds like a hydraulic problem.
Andrew
Old 05-14-2016 | 02:09 AM
SteenH's Avatar
I've seen bad slaves cause really strange problems without looking out of the ordinary. Be my first guess. Best of luck
Old 05-15-2016 | 12:34 AM
Darth_V8r's Avatar
Moderator
I went through three consecutive stock masters. Just cause you replaced the master, if you didn't use a quality master, it could still be the issue
