Clutch petal sticking/rough only when engine is running
Old May 11, 2016 | 11:47 AM
dockSS's Avatar
Default Clutch petal sticking/rough only when engine is running
I have a 99 camaro with a Tick adjustable MC, a Tilton adjustable throw out bearing, factory LS7 flywheel and and clutch. Clutch petal is fine until you start the car. Once started the petal will stick to the floor and if I increase petal travel it will release but come back very jumpy. I replaced the Tilton adjustable bearing yesterday with no luck. Anyone ever have this issue?
Old May 11, 2016 | 01:29 PM
Darth_V8r's Avatar
Moderator
to me, that sounds like when the adjuster mechanism on the stock style clutch is sticking. Results in low or no return pressure from the pressure plate.
Old May 11, 2016 | 03:22 PM
dockSS's Avatar
Seems odd that it only happens when engine is running though?
Old May 12, 2016 | 12:48 AM
Darth_V8r's Avatar
Moderator
it's been too long since I've had clutch trouble. I never remember it acting up with the engine off, but i truly can't say with 100% certainty that it never did it unless engine was running.
