One piece T56 Countershaft (Z06/SSR) endplay clearance
Is there anything different that needs to be done when checking for endplay clearance / shimming when a 1 piece counter shaft is being used instead of the two piece?
Anything I find when I search is related to the two piece, which is what is in the T56 manual.
The front of the one piece CS has the notch for the Z06 cooling pump to fit into.
The rear of the one piece CS uses a straight bearing, rather than the tapered bearing that the two piece CS use, so is preload is less of a concern here?
