Snapped T56 Output Shaft
So my local track was finally pretty well-prepped and my ET Street Radials stuck enough to destroy my output shaft.. So, Tick is about to receive some more of my business for the level 2 rebuild with Viper mainshaft. My question here is this, which yoke will I need? I have the 3" steel PST driveshaft going to my Moser 9" rear. Wondering if the 1350 ujoint I already have on the driveshaft will work with a new 30 spline yoke? Any help will be greatly appreciated!
My setup is in my sig, it's MS3 camonly, monster level 3 with tick MC, Moser 9" 4.30's wavetrac with RTS' and 275-60-15 et street radials and I launched close to 5k lol. From the same track, I usually would leave from 4500 but would roast the tires or if I left lower it would bog so after seeing how sticky the track was being, I swung for the fences but since it finally deadhooked, the output shaft didnt appreciate it lol
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I'll post a pic of the cleanest sheer of the output shaft ever lol, looks like I took a bansaw to it and chopped it off straight as hell
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Yessir, I can never hook at Lassiter but when I finally did, this happened lol![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
It's all good, and I see that now! Gonna have to give it a look, preciate it
It kinda fell out with the output shaft lol. Luckily with the new viper mainshaft I'll have a new bushing and seal anyway
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
What kind of 60ft time's were you pulling before you broke this? I have had about 15 launches in the 1.3 range about 20-30 in the 1.4 range and couldn't count how many 1.5 range all with the stock mainshaft and pretty close to full weight. ..that sucks that happened but you might want to put some time into learning how to clutch slip or get a slipper clutch cause a side step straight dump of the clutch will break stuff over and over....if you leave on spray maybe have some sort of delay or something
