-4 vs -3 Clutch Line
Hey guys, trying to chase down an issue with my clutch setup. I have a LS1/T56 in a RHD Nissan S14. I am using the stock GTO master cylinder, with -4 AN fittings and braided line down to a new slave and mantic single plate clutch setup. I am 99% sure it has no air in it, but is impossible to get into reverse with the engine running, and hard to get into first. Once driving low rpm gear changes are OK, but impossible to change quickly at WOT. I notice every other setup I see uses -3 clutch line, I can't see it making any difference .. but could this be an issue with my setup?
Not enough disengagement. You might try a TICK shim behind your clutch slave if you're positive there's no more air in the system and everything else is good. When you get it apart do the measurements to determine the thickness size you'll need. The procedure is on their site. They work well for this very issue. Doubt it's line related.
Make sure there is no air in the system. What kind of clutch are you using?
Andrew
