Odd inconsistent clutch pressure issue....
If not than bleeding the system with the fill nipple lower will trap air in the system while bleeding.
FWIW I also have a Wilwood MC (McLeod) and have it mounted in a custom pedal assembly for a car that was never built as a manual car.The MC mounted in my pedal assembly has the fill nipple pointing down so I had to bench bleed the MC.
I Tried Mighty Vac several times with no luck
Disconnect the slave, use a screwdriver to push open the check valve while assistant pumps pedal. DO three pumps, fill the reservoir, do three more. You might get a burst of air out the first time or two and then it quits. Reconnect and bleed slave.
You could also have the seal in the master internally bypassing, which is unlikely, but sort of sounds like what you have. Especially if an in car bench bleed doesn't help.
I assume you have the Wilwood "compact" MC mounted in some fashion to your pedal assembly. Maybe "moving" it slightly while bleeding (bubble can hang up inside so slight tilting back/forth while bleeding may dislodge any bubble
Pic of my Wlwood for my McLeod Twin clutch. Mcleod makes the adapter for my model to mount as a 94-97 F-body would...but in my "custom" pedal assembly designed to use a F-body MC...its orientation is not with the nipple at the highest point so I had to bench bleed. I actually bleed the entire system as I can remove slave and install Reservoir, MC & slave as a sealed unit (LT1 car). Your LSx you cant as slave is part of TO bearing IIRC.
You can contact Wilwood direct for ?'s on their Tech line. I suspect they have a MC rebuild kit if that is what it turns out to be.
are you losing any hydraulic fluid?
