Tick Performance Master Clylinder
http://www.tickperformance.com/tick-...-firebird-ls1/
Not sure what I paid, but it was a lot less than that on a group buy. Still in a box so can't comment on anything but price, but still......$100 discrepancy.
To SAPPER's comments, nothing in the OP's thread seems shocking to an experienced member. This is not an OEM part with OEM fitment and it is well-established that the part is not one for a rushed novice install. (An experienced mechanic is still a novice the first time they work with a certain type of car or part...)
whatsa347 pretty well summed up the engineering profession. The other cool thing is that on the internet, we can all be whoever we want to be...
Hopefully some of the other information in this thread will help keep others from getting over their heads or be prepared for the extra effort it takes to install the part.
The stock cylinder from GM actually is a better piece of engineering, and the C5 cylinder which is the "improved" cylinder is far longer... maybe 2-3 inches longer than the Tilton. Really the Tilton is a weaker cylinder... it's smaller so it pumps less fluid! Therefore it's weaker.
Another dumb thing is that the pedal will be sticking to the floor with the Tilton. This is not a cool thing, it's a dumb thing. There is nothing wrong with the C5 Corvette MC. It works very well in the Camaro SS. It is one of those OEM parts that cannot be improved upon.
Also, i'm not just trusting what my transmission mechanic said. The main problem with the Tick is the Tilton. It's really not a great cylinder. It's actually the cheapest cylinder $$$ can buy.
The stock cylinder pushes more fluid. Period. Don't believe me? Drop it in some Dextron 3 and suck it up in a bucket!
<Insulting, non-technical comments removed... again>
Last edited by wssix99; Aug 18, 2016 at 10:49 PM. Reason: inappropriate comments removed
Hope it gets better from here. I've seen where the aftermarket one now has an aluminum body. Never really seen one or researched it much further than seeing it online.
Look at how the stock one for the C5 is longer. It also has a better feel. These are hydraulic clutches. The pedal snaps back because of the pressure from the fluid, not a spring.
What is PARAMOUNT is how the mechanic adjusts the FORKS and the CLUTCH assembly as a whole. The Tick cylinder will just make your life harder.
Does the C5 unit "fix" any of the factory problems that the Tick is supposed to address?
While the C5 unit might be better than the fbody one, C5 guys are still having troubles with aftermarket clutches and are having to upgrade their MC.
The peddle sticks to the floor with the stock unit, not the tick unit. If the tick unit is sticking to the floor you need to adjust it.
Irony at its best. The stock setup has a SPRING on the clutch peddle(yet still gets stuck down) tick suggest removing this spring when installing their MC.
There are no fork or clutch adjustments on a LS1 t56. You can shim the slave, but that's about it on the transmission end of things. Even if there were, a Tick MC wouldn't make life harder. It's just a MC with an adjustable rod, that doesn't affect adjusting a clutch fork or slave at all.
I've got a stock CMC in my 01 TA and a Tick in my GTA with a stage 2 Monster clutch. The stock one is too soft and requires too much travel for me. I much prefer the feel of my Tick with the upgraded clutch. People have complained about the pedal effort on the same set up, but a person would have to have some seriously weak legs to feel like it's too strong. Also a lot of people don't know not to hold their clutch in the whole time they are at a red light, and then they complain about pedal effort.
In your case you are FALSELY bashing, as in just about everything you are saying is wrong, I still feel like we are missing something in this story that you are not telling, as you clearly don't know what you are talking about.
Mr./Mrs. Blackenedss has chosen not to abide by our site rules, after much coaching and encouragement, and will be taking a vacation as a result. We can see if this member picks things up positively in a few weeks.
