Clutch Hose O ring leaking
So I just replaced my clutch and did the drill mod on the clutch hose. Now after getting it all back together I noticed the master cylinder was leaking from the hose connection. I pulled it realized I forgot to put the O ring on the end of the hose put it on thinking well that will solve it.
Annndd it still leaks. Built up pedal for a bit when I was bleeding using the mity vac never went over 10 hg. Then started leaking again. Anybody know any fixes for this? Do I need a new O Ring or could I put something on it to seal it up. Any help is appreciated really need this car driving as I'm leaving for college in two days
