Slave cylinder replacement
Old Sep 7, 2016 | 12:31 PM
2002ws6in13's Avatar
Default Slave cylinder replacement
I have a spec2+ clutch in my car and need to replace my slave cylinder. Any suggestions on an aftermarket one??
Old Sep 7, 2016 | 12:51 PM
pozesd99''s Avatar
Dont get aftermarket. Get an oem one
Old Sep 7, 2016 | 04:08 PM
99SSJarhead's Avatar
GM replacement slave cylinders (01+ fbody type) are usually what even the aftermarket transmission builders use. I'd stick with that.
Old Sep 8, 2016 | 01:38 AM
Darth_V8r's Avatar
Moderator
Yup! The weakness in the f body hydraulics is the master. Slave is fine
Old Sep 8, 2016 | 10:39 AM
Thanks for the help. I'll stick with oem and I think I will do the drill mod on my master cylinder.
