T56 - No Reverse
The car still runs and drives fine. No problems in any other gear whatsoever. I was simply turning around and lost reverse. It just grinds anytime I attempt to put it in gear. I tried getting into reverse with the car off as well. It will start to go in (enough that it triggers the back up lights) but if I bump the ignition with it like that the car doesn't move. Same thing goes if I push the clutch in and start it, reverse lights stay on but it just grinds.
I have that sneaking suspicion that it's going to end up being a bent fork, but as I said, I want to make sure I'm not missing anything before I pull it off and send it somewhere to have it replaced.
