T56 getting hot!
How hot is too hot on a t56? It peaked at 231 but the normal operating temp is 180s
Anything I can do to get the temps down on it for future temps?
Not necessarily the easiest solution though.
Or simply adding more fluid may well reduce overall temps. But it's rather unusual to have a trans temp gauge in the first place ? Have you been breaking boxes or something ?
About 220 F the ATF will start to break down quicker but still fine in the manual trans. Not a real issue, just shortens maintenance intervals.
For an external cooler, it can be done with belt driven pump or electric scavenge pump through fill/drain ports without interfering with splash lubrication design. Not a lot of cfm required but the pressure needs to be able to push it through a cooler and back up into the fill port. Heat sinks on the pan or fans on the trans body won't make a big difference.
I've always run 4.5 litres in mine since I've been using an LS, and that's some 13 years or so and never had any leaks.
No idea on temperature differences between gear oil and ATF, but I run a gear oil in mine.
I'd think with the turbos down low on mine and everything being pretty tightly squeezed in things could get hot, but I've never had any concerns or problems to actually monitoring temps
ATF is thinner and has detergents. ATF will expand more when heated while detergents clean leaks (opposite of stop leak lol) so puking from shifter or vent tube will happen easier than gear oil.
Ever figure what your issue was back in 07?
https://ls1tech.com/forums/manual-tr...ther-tube.html
People seem to use all sorts of oil in them, and all sorts of grades so hard to say what is right or wrong. OEM use ATF though, that is for sure.
not sure why it "seems" to be running hotter than others have said but no circumstance is the same with multiple cars. the last trip i just got back from it peaked at 215f not much for grades but the cruise was set on 90 for a looooong time. its gonna build some heat with that secondary shaft spinning that fast for that long. i would still like to see it under 200 on the same conditions.
it gets changed out once a year so i suppose its not overly serious. tremec is not concerned until it hits 275f, then its dump fluid pronto. much more than that and im sure things will start to melt.
