Clutch Problems [T56]
Old Sep 19, 2016 | 08:51 PM
dallasmotox's Avatar
Default Clutch Problems [T56]
Clutch sticking to floor if I stay on it for a few seconds in first or reverse, I flushed some new fluid through it with no change, any help? 1999 Z28
Old Sep 21, 2016 | 12:59 AM
pozesd99''s Avatar
Buy a new oem slave and throwout bearing. Problem solved... Also would invest in a adjustable master
Old Sep 21, 2016 | 07:03 AM
R6cowboy's Avatar
I agree with the above. Replace the slave cylinder and it's ideal to also replace the master cylinder at the same time.
Old Sep 22, 2016 | 07:03 PM
Centerforce's Avatar
Agreed; that is usually the sign of a failing internal seal in either master or slave.
