T56 swap
Old Nov 7, 2016 | 04:22 PM
Jimberndt's Avatar
Default T56 swap
I'm looking at doing a t56 swap on my ls1. Stock bottom end, ported and polished 5.3 race heads, torquer v2 cam and a tune. I know I need to have the computer flashed to change it to a manual set up but will it ruin the tune I have in it already? I have already put 3.73 gears in the rear preparing for this, any other advice for swap would be much appreciated.
Old Nov 7, 2016 | 04:55 PM
BALLSS's Avatar
your tuner would be able to make any adjustments for the 6 speed swap
Generally they would start with a M6 bin file and then adjust that for whatever other mods you have regarding the motor
I did a A4 to T56 swap in a B-body which at the time had a H/C/Gear/Injector/TB tune. It was not problem for my tuner, Ed Wright.
Old Nov 7, 2016 | 05:23 PM
Jimberndt's Avatar
It's not a tuner I had it done by Turbo Specialties in Amarillo there is no box with it. But i get what ur saying they won't be messing with anything that has already been adjusted
Old Nov 8, 2016 | 12:22 PM
BALLSS's Avatar
Beyond just the transmission adjustments there will likely be some adjustments in the tune...idle RPM for one since you will have a M6
Turbo Specialties, who you said did your tuning, should be able to deal with all of it
Old Nov 12, 2016 | 08:36 AM
Jimberndt's Avatar
My car is a 2000 and the car I'm getting T56 out of is a 95 can I use bell housing clutch computer peddles slave and master cylinders? Or is there a difference?
Old Nov 12, 2016 | 02:54 PM
BALLSS's Avatar
...ah yes there is a difference
will not bolt up to the LS block
Old Nov 12, 2016 | 03:47 PM
Jimberndt's Avatar
Im reading something about the 93- 95 being from a first gen lt1 not being able to change the input shaft case the gearing is differnt, do you know anything about that? I really wanna do the swap but i want to make sure I get the right tranny to swap.
Old Nov 13, 2016 | 11:49 AM
BALLSS's Avatar
you need to find a donor T56 for the LS motor, not the LT1 motor
