Spec 3 shimming
Old Nov 18, 2016 | 09:49 PM
TheBandit18's Avatar
Default Spec 3 shimming
I have a 99 corvette swapping the clutch in and I measured to see if I need to do any shimming and from the top of the bearing of the slave cyLinder to the torque tube is 2.300 and from the pressure plate teeth to the bellhousing was 2.346 is this way to close or am I messing something up?
