Growling noise while in gear
I'm running a new SPEC 3+ with a freshly machined SPEC steel flywheel.
It makes the noise under the following conditions:
While coasting to a stop with the trans in gear with the clutch pushed in.
It does not make the noise when in neutral.
I can stop the noise by placing the trans in neutral and letting the clutch out
It will continue If I put it back in gear while moving with the clutch pushed in
Under no circumstances will it make noise with the clutch engaged.
The noise sounds like a bad throwout bearing but its not acting like a typical throwout bearing issue. Anyone got any ideas?
ie there will be no moving parts in the trans at this point.
Although from your description, release bearing does sound likely.
I did put a new pilot bushing and input shaft in when the trans was built.
I'm pretty sure its the pilot bearing at this point but I'm really hoping I don't have to pull the trans again. I'm running GM Syncromesh with carbon sycros. Any chance that could be the issue?
This is an LT1 T56 btw
