Clutch break in
It's a mere formality to allow some bedding in of the surfaces.
I guess you could compare it to someone claiming your brakes need bedded in for 500 miles before using them....wouldnt really be practical for a race car. Nor would bedding in a clutch for 500 miles on drag race only car.
Just dont slip the ***** out of it, give it some fair usage and it will be fine.
And if you're nowhere near the capacity limit of the clutch, I wouldnt worry one bit.
Basically you don't want to slip a new clutch as the disc will glaze and the clutch will not work well after that
IMHO I think 500 mi is a bit excessive but the clutch companies are just covering their *** against warranty replacements
Basically just like new brakes you don't want to slam them when new. Let them go through a few heat cycles so the friction material can bed with the hard surface (rotor)
Race cars use ceramic or iron composite disc and change the clutch discs often
What you don't want to do is throw a brand new clutch in and do WOT dyno pulls on its first mile of life because it will either be severely compromised, or fail completely.
