Short Shifters
The very first thing I did when my car was delivered from the factory was replace that damn shifter. Best thing I did ever - and I didn't get the greatest shifter. Then I put a short stick on it - second best thing I did ever.
This is the latest thread we have going on regarding shifter developments: https://ls1tech.com/forums/manual-tr...available.html
If it's a track only car, you could also try shimming the detent with a 0.050-0.100" copper washer gasket. The potential downside is that the car can come OUT of gear easier just driving around. If it's track only, it should get rid of that almost two-step feel of your shift - you know where it sort of stops in the middle just briefly and then drops into gear.
In my swap project, I'm running the GTO triple carbon syncros on three 8 inch full faced discs and have datalogged 3/10's of a second shift, that clutch switch on to clutch switch off and it's at the top of the pedal.
I'm using one of the eBay quick ratio shifters combined with a short throw stick. I really enjoy the feel of it
